Problem Split ouput
Hi, I have version 2.2.2, when selecting the option “Split Output”, headphones icons do not appear. I can not do Pre-cueing.
In Apple devices icons appear above the vumeters.
This is normal?
*Use Dj Cable.
Regards,
Hi Joaquin,
This is the expected behaviour. The pre-cueing channel is set automatically as soon as you moved your crossfader all the way on deck.
Be assured that we’re always working on improvements for djay2 for Android.
We kindly ask for patience in the meantime!
Best regards,
Lukas
