I have discovered new futures like tidal and soundcloud go + and look what a surprise is not working .
SC go + don’t cover my country, tidal is not connected.
And the worst thing is near Spotify end connection.
I’ve never feel disposed like this.
Sorry but you gays doing In the wrong direction.
Thanks for your feedback. We are looking into the TIDAL error you sent. It would be great if you could let us know / check about the following:
- Is the date/time correct on your iPad?
- Have you travelled or changed country since logging in?
- If you use https://whatismyipaddress.com/ what country does it report?
- Yes is correct
- No I’m not
- Yes I checked Bulgaria is not supported for now
