Problème de connexion entre l'application djay et ma
Bonjour,
Je n’arrive plus a connecter ma Hercules DJControl Mix Blue Edition a l’application djay… malgres la réinstallation de l’application. Si quelqu’un a rencontré ce problème et autait une solution (idem avec un autre smartphone)
Merciii
Hi @Stoph37000, please write your topics titles and post in English. Thanks!
Good morning,
I can no longer connect my Hercules DJControl Mix Blue Edition to the djay application… despite reinstalling the application. If anyone has encountered this problem and has a solution (same with another smartphone)
Thank you
When creating new topics, please do not forget to answer the questions in our template with specific details about your setup (not just “iPad” or “Latest Version”). This helps all of our community moderators to provide the most effective support to users with the utmost efficiency. Thanks.
Device model (ex. 2020 iPad Air 4th Gen):
Hardware/controllers used (Reloop Ready):
