Problems on Windows
Hallo,
I am now trying to test it in two different pcs (both windows 10 desktop versions later than 1607) but it only works in one of them. In the one that is not working, when i start the app it seems to try to start and then it closes itself in a few seconds.
Do you know what could be happening?
Best reg
Hi @Andre21,
Welcome to our community and thank you for reporting this problem.
In order to investigate this together, we’ll need more information from the computer that’s failing to open djay PRO for Windows 10. Please send your PC specifications to support@algoriddim.com. We’ll guide you via email.
Hope to hear from you again :hugs:
