Problems with Djay Pro:
- There is no beatgrid edit.
- Sync does not work in 50% tracks. Beatgrid is offbeat so sync goes off-sync.
- BPM and KEY detection are wrong in 30% tracks.
- No inputs. I need inputs for iPhone/iPad sounds.
- No sample tracks. Sampling from tracks sucks as you can’t load your samples.
- Only one controller supported. I want to use iPad as other controller for FX and 4 tracks.
Where is Djay Manual?
