Problems with Phase Dj
  • Device model (e.g. 2020 iPad Air 4th Gen): win 11
  • Version of operating system (e.g. macOS 14.4.1): Windows
  • Version of djay (e.g. 5.1.2):Last version
  • Hardware/controllers used *Phase Dj last version
Hello, I can’t get Phase DJ to work with djay Pro.
I only have one turntable and a computer with Phase in HID mode.
But unfortunately, djay Pro doesn’t recognize it! Where could the problem come from?
I’m using Windows 11, the latest version.
I have installed ASIO drivers, but nothing appears in MIDI. However, when I downloaded Virtual DJ, it recognized it immediately.
Thank you in advance.
Hi @Dlp_77, welcome to the Community! Sorry to hear you’re experiencing this issue. Please refer to the linked setup guide below and let me know if this helps or not.
Yes, thank you, I know that!!! But that doesn’t answer my question in my case!!!
Okay, thanks for confirming @Dlp_77. To help me better understand what’s going on, can you please try to capture a short video of the issue, upload it to your Google Drive/Dropbox, enable sharing permissions, then share a link to the video here? Thanks!
My question is: Do you absolutely need to use a DVS mixer?
@Dlp_77 according to the setup guide above, you don’t need a DVS mixer if you’re using HID mode. Otherwise you do.
Can you please confirm that you have an active djay Pro subscription?
