Qbert Scratch Sample Intro (Glitchy) Sound
Is there a way to remove the green (glitchy sounding) block that appears right before the scratch sample’s wave form on iOS and MacOS. It almost makes the sample unusable for me. Thx.
Hi @Reign712, there’s no way to edit this built-in sample. However, what I’ve done is set Hot Cues on the various parts so I can quickly jump to the exact scratch sound I want. Alternatively, you could load your own scratch file onto the deck.
Thanks I have hot cues set. The tone is just so close to the sound that there isn’t any room for error. It got me wondering if that’s the reason it’s there in the first place, to help train?
Yeah, I’m not sure, but that could be the reason.
