I’ve been using Djay for IPhone for a while now to put multiple songs together. But when I record the same song multiple times the quality of the song drastically goes down. I don’t know the reason but is very annoying if i want to make a mixtape of about 10 songs.
The result is that the first song’s quality is crap,but the last song(s) have good quality.
Is this normal or can you do anything about this?
Hi Elliott Strum,
can you send us your recordings or make an exemplary video of the described behaviour via support@algoriddim.com?
That would help us tons.
