Hi guys,
I cant log into tidal as the app on quest 3 says I have to update it (tidal upgrade required). How on earth should I do this? Apple Music said the same thing. It is a pro account so this is not the problem
Awesome grogram otherwise!
Hi @Johnny_Beatmann, please make sure you have the Tidal DJ Extension Add-on with your subscription.
Hello! Itβs been more than a week since my last reply. Iβm going to consider this topic completed for now so I can focus on others. However, please feel free to respond and we can definitely revisit this. Thanks!
