- Device model : Meta Quest 3
- Version of operating system : Latest
- Version of djay : Meta Quest Latest
- Hardware/controllers used : That is the question
Hello!
I’m hoping someone can clarify some questions and or help. I’ve searched around and not found quite what I’m looking for.
I’m looking to pick up a controller thats compatible with the quest version of Djay. I currently run a Rekordbox DVS setup, and am looking to switch to a controller. However I need to still be able to use Rekordbox as I do need to play out fairly often. I also should probably still play my vinyl to justify my financially crippling addiction to it so I need phono in at least (not necessarily DVS).
The DDJ-800 looks to be perfect, but doesn’t seems to be supported. It seems the Rekordbox compatible controllers with phono in are absent from the compatibility list, are there plans to get them working, or is it just not in the cards due to some other issue?
