Question about DVS set up via soundcard
Can anyone help me out and let me know what sound card I would need to use djpro through my old analog mixer?
I have seen a few people mention solid state ssl2 mk2 and wanted to know if it’s easy enough to set up?
If you want to use DVS then I’d say something like a Reloop Flux is needed, I’m not sure if standard sound cards support timecode signal, but I may be wrong.
Traktor Audio6
Does that still work? Was unsure as it an older unit nowadays
Hi @Chris1501, welcome to the Community! You could also consider the Reloop Flux or the new Reloop Flux Go.
Another fantastic thing about the Flux is the ability to charge your device whilst plugged in with the single USB-C cable… it’s arguably one of the best features offered by Djay on modern iOS devices, no extra charging, no camera adapters etc. makes for a really clean setup.
