Question about iPad 2025 performance
Hi friends,
I’m thinking about purchasing an iPad 2025 with A16 processor to enjoy the full djay experience.
My main question is if it will run fluent and smoothly in this device or I should buy a better one.
Another doubt is about size, are the 11 inch enough?
Thanks a lot in advance.
It will be fine but I ended up going for the iPad Air to future proof myself.
11’’ is fine for size considering laidback Luke dj’s off his iPhone
Hi @Konejo, please refer to the linked FAQ below for more info on iOS devices.
https://help.algoriddim.com/hc/en-us/articles/360014572919-Does-my-iOS-device-support-Neural-Mix-and-at-which-quality-level
Thanks for sharing @maurizio_T!
OK thank you very much! I saw that url @Slak_Jaw and with so many releases I would suggest the last update date for that doc.
Thanks again folks!
You’re welcome @Konejo. Thanks for the additional feedback
That page is helpful but it doesn’t list an a16 chip iPad
@eyeseeyou01 I believe the A16 chip is used in the iPad 11th Gen so, according to the link I shared above, it should support 100% NM Quality.
