Question about playing one song multiple times in a row
I’m using the djay app on a iPad (7th generation) A2197.
I’m helping with an event & the host wants to continuously repeat a 15 minute audio segment as background sound as guests arrive over a 2 hour time window
What’s the simplest way to get the software to repeat a song multiple times without having to be in front of the ipad every 15 min to restart the song?
Hi @Derv,
  1. Try creating a playlist that only contains this song.
  2. Navigate to Settings>Modes then select the Automix icon near the top left.
  3. Select the Playlist containing that song.
  4. Then select the Repeat icon.
I’ve always thought how that could be done,
Thanks Slak
You’re welcome @maurizio_T
