I notice then when you are done with the autoloop, the track “skips” ahead to where it would have been had you not done the loop. I’m wondering if that can be changed with an option to simply continue on from where you stuttered? In the waveform display this is possible with the slip mode vs non-slip mode, but in loop mode when pressing the quick loop keys, it seems it’s not possible …
Bounce loops are designed to work as you described. If you wish to have a “traditional” loop function, then you need to use the manual loop.
