I purchased Djay Pro for Windows 10.
I wanted to ask if it is possible to adjust the speed of the Crossfade? When I click on the “arrow” right or left to switch from one track to another, it seems to me to be very fast, I wonder if it was possible to set the fade speed. I await your suggestions, thank you
go to PREFERENCES>AUTOMIX and there change the DURATION parameter. That will affect the speed at which the fader moves. You can set it in time or in bars.
Hope this helps!
