- Device model (e.g. 2020 iPad Air 4th Gen): Ipaid Pro 12
- Version of operating system (e.g. macOS 14.4.1): 17
- Version of djay (e.g. 5.1.2): 5.1
- Hardware/controllers used (e.g. Reloop Mixon 8 Pro): Mixon 8, Beatpad 2
Your question:
I’ve read through a couple of threads on here. I’m still in practice phase regarding scratching. So there are a few beats that I use and a few different scratch samples. I notice in the session view on the top left of the navigation pane, it’s sorted by date. That’s cool. But is there a way to make a playlist like for instance Practice and throw my 2 commonly used samples in there? I did see a thread on exporting to excel, but that doesn’t really tell me much. Of what use is exporting a session to excel? I want to create and name playlists with the samples in there, instead of going by date and trying to find the ones I used.
Here’s what I’m talking about with the excel export. Of what use is this?
- First navigate to My Collection within the Library
- Then at the bottom, choose History
- From here you can select your Current Session or any previous session
- Finally, you can export the playlist as a CSV
