After the most recent update the queue list is no longer working. I have a song stuck in the list which I cannot delete and also can’t add any other songs to the list. I use automix daily and now am stuck without it for tonight. The last few updates have caused nothing but problems. I need a dj app I can rely on on a daily basis that intergrates with Spotify and Djay is no longer that app.
I am using Djay 2 and iOS 11.4 updated this morning.
Any news on getting this fixed? I desperately need to use automix and not having it is a massive problem for me.
Hi Jim, I deleted the app and reinstalled it. That seemed to sort out the problem but you will lose all your settings and history which is annoying. Algoriddim were useless at sorting this problem or even just communicating.
This is killing me as well. Please fix asap!!!
I am using djay on my iPad… Version 2.8.20 iOS 9.3.5
When I try to edit and clear or hit delete, no response…and now the song is stuck in there twice!
Thanks Paul…that seems to have fixed it. Did lose all my settings as we knew would happen. 8700 to analyze…yay (without key detection to help it go a little quicker). You save me quicker than Algoriddim
we are very sorry to hear that.
Can you tell us exactly which djay version and iOS version you are using?
we are working on this and will provide an update soon.
Stay tuned.
