random crashing
Not sure why…I know I will not get any answers because the issue is so nebulous but…
DJ pro AI randomly crashes at times
I run a MacBook Pro (15-inch, 2019)
2.4 mhz intel core i9 32 GB memory
Usually use four decks for convenience…switch to two?
Seems to crash most often when I search as song plays. Generally random. Anyone else? Thank you
I will assume all is up to date, software and Mac OS?
Thanks for the email.
I did not update to Ventura…always wary.
Currently using Mojave
Ok and the DJay app? Let’s see what others say about the new version of Mac OS before you update
Using 4.1.7 Dj…good idea to see if any issues with Ventura…thank you!
