Random songs play instrumental only during Automix
  • Device model (e.g. 2020 iPad Air 4th Gen): iPad Pro (12.9-inch) (5th generation)
  • Version of operating system (e.g. macOS 14.4.1): 18.4.1
  • Version of djay (e.g. 5.1.2): 5.3.1
  • Hardware/controllers used (e.g. Reloop Mixon 8 Pro): Reloop Mixtour
Summary of the issue:
When on automix, random songs will play with instrumental only. Used it recently to dj a salsa night and it happened a few times.
Can you shed any light on this?
How to reproduce the issue:
Hi @Paul, which Automix transition are you using?
Looks like the default transition is automatic. That doesn’t explain why the whole track plays instrumental only, surely it should just be the transition period.
Thanks for confirming @Paul. With this setting, djay will cycle through all of the available transition options in the list. I suspect this could be related to the Neural Mix (Harmonic Sustain). Can you please try setting your Automix to this option and see if you can replicate the issue? If so, please try to capture a short video of this. Thanks!
I tried that and it didn’t happen, however I managed to capture it the other day briefly.
Thanks for the video @Paul. I’ve passed this onto engineering to see if they can reproduce this. In the meantime, is there anything else happening that you think could be contributing to this?
Can’t think of anything that would be causing this. It only started happening since the 5.3 update.
Thanks for your help.
Okay thanks @Paul. Engineering was able to replicate this and they’re working on a fix which should be released in an upcoming update (likely 5.3.2). Thanks!
Is there a way to fix this once it happened, other than restarting the app?
Hi @feierlaune, please try disabling Mute FX.
OK, thanks will try!
I’ve been noticing this too. Glad it’s not just me
Thanks for the additional feedback @eyeseeyou01
No problem.
Also when this issue happened I double checked the eq and neural mix toggles and nothing was enabled. There may have been something I missed but it was driving me a bit crazy.
I have the same problem since 5.3 update, but on MacOS now 15.5 / Macbook Pro 16 M2.
I found out one resolution: if i disable „reset neural mix controls“ in common settings, all is fine.
In german „Neural Mix-Steuerungen zurücksetzen“ at „Einstellungen / Allgemein“. I hope my translation is good.
Thanks for sharing @Tiger_s_Claw
