Just got a Rane four today and setting it up on a laptop connected to TV soundar and sub until I get external speakers
All works except the 4 channel volume faders and the 4 channel EQs
When I switch to neural vs EQ in the software I can higher and lower Stems sounds
But the lows mids and high, nothing on all channels and nothing on the volume faders
On a Windows PC (win10)
Updated Rane four to latest version and Djay pro up to date
Right now it’s setup under internal mixer, I tried playing around external mixer for all players, when I select Rane, I see the lights besides the channels but no audio
The mixer is a standalone mixer. That means you don’t see anything in djay pro of you touch the eq or Fader. Check, if the faders in djay pro are at full level and also the master volume (I the left upper corner) is not muted. Also check crossfader settings on your device.
Also, do you have the appropriate Deck Source (USB A or B) selected to match the USB socket on the back you are connected to? Same goes for the USB/Line Source Selection (see below from the RANE FOUR user manual)
I guess with PC audio out to sound bar was problematic
My only thing now is that on the right deck the cappella and instrumental buttons are inverted but I assume that’s something that can I get used to or manually map
