Device Model: Macbook Air M3
Version of operating system: MacOS 15.3.1
Version of djay: 5.29
Hardware/controllers used: Rane Four
Hardware Firmware Version: 1.7.0.8
Summary of the issue:
Sometimes I map the low eq to control all three high, mid and low. This works in my other controllers but not on the Rane 4. When I switch to neural eqs it works but when I use the standard eqs it only controls the low. It ignores the high and mid and it also does something strange in the mapping, it automatically duplicates the mapping again on deck 4. Below is a link to a google drive video showing this behavior. This may be because it is an external mixer and it gets overloaded but not sure why it only does that when I am in standard eq but not in neural mix. Mapping them all to the low makes my transition smoother and quicker depending on the genre.
How to reproduce the issue:
Actually, looks like there was some sort of mapping error. Once I deleted the duplicate mappings and tried it again, then it worked. Looks like when I duplicate a mapping, if I duplicate it again, I have to duplicate the original control, not the other duplicate. Once there is a mistake, any change automatically creates a new mapping record and it just keeps going on and on.
So, I was able to fix all of my custom midi configurations, but the build in midi still does duplicates the mapping when I touch any eq and I never change that one because I can’t so the problem is still there with the built in rane 4 midi, for the other ones, I duplicated the original and then fixed it and then deleted the original and now it works. I will attach my custom midi files so that you can see that in my versions it is fixed but your built in midi causes issues. Just use a diff tool and you can see my fixes.
RANE Four (Built In) Fix.djayMidiMapping (346.0 KB)
Instant FX.djayMidiMapping (344.9 KB)
