The Rane 4 effects panel is pretty much unusable with MacOS DJay Pro. I am running version 5.25 on mac 14.6.1 m3 with 16 GB ram with the latest version of the Rane 4 software installed on my Mac.
When I toggle on the effect, it always picks FX1 regardless of the button that I pressed. What I have to do at the start of my sets is click all the buttons on and off a few times on both the hardware and software side and trigger the fx and then it syncs and starts working. Even when I switch to the onboard Rane 4 effects, it still triggers the DJ Pro FX1. Whenever I forget this, it just results in a mix error. Basically, I stopped using it all together because it is so buggy. There are other bugs too but once you test it out you will see what I mean. Here is a link to a folder with 3 videos Fx bugs – Google Drive
Video 1 shows the software fx not selected but when I trigger it, it picks fx1. It shouldn’t pick anything if none are selected.
Video 2 shows software fx 2 selected but when I trigger it, it picks both fx1 and fx2.
Video 3. I flipped to hardware fx and when I trigger it, it picks software fx1.
Basically, you have to click around a bunch of times before it figures itself out and starts working properly. I’m guessing the same behavior exists on the Rane Performer with the fx panel being identical.
I’m really regretting this purchase at this point and I should have brought it back when I submitted the initial bugs that still haven’t been resolved. Please fix, I really love everything else about this controller minus these bugs with DJay pro. These bugs do not happen when I use Serato and other software.
The best way to reproduce this is to turn the controller off and then back on and then reconnect via usb.
Hi @Rocky3000, thanks for the details about your setup, the issue and the video. This is super helpful. I’ve passed this onto our engineering team to see if they can replicate the issue and offer any suggestions. In the meantime, can you please confirm that you are using the latest firmware from
RANE and if you are using the “built-in” MIDI mapping or a custom edit? Thanks!
Hi again @Rocky3000, our team was able to replicate these issue and is actively investigating solutions. I’ll report back when I have more news. Thanks!
Was your team able to come up with a fix for the Rane 4 effects not working? I’m on all the latest software on Mac and the Rane 4 controller, and it’s been a couple of months since your last post (January 20, 2025) is the current date, and the Rane 4 effects section still isn’t working properly. This one big issue is the only thing stopping me from making djay Pro my permanent software.
Is there something I have to do on my end in the settings to get it FX working properly? I didn’t have much time to play with it last night I just turned it on to see if was working just from plug and play and it wasn’t.
Naw the built in controller effects still dont work plug and play on my rane 4 with dj pro software and my macbook pro. I just gave up on the software went back to what was using honestly because as much as I wanted to like dj pro the partnered software it came with simply just works without any effort.
