Rane 4 or Flx 10
I’ve had enough of mine Mixon 8. Rubbish quality. Have any of you guys got experience with the two above controllers and the DJay pro App? Opinions please. I’ll be using it with my iPad Pro.
Rane four isn’t class compliant so no iOS, which is a bummer
@Nubium here’s the support list for iOS. Instead of the RANE Four you could consider the Denon Prime 4. I have one and it works great with djay.
Other 4 Channel Options include:
  1. Denon SC Live 4
  2. NI Kontrol S3
  3. Numark NS4FX
  4. Pioneer DDJ-GRV6
