Rane 57 MKII compatibility
Anyone use a Rane 57 MKII with algoriddim or have access to one they could test for compatibility? I know it’s class compliant but I’ve also learned recently that not all class compliant mixers work with iOS devices, especially older ones (Denon dnx1600). I found a good deal on one and love the simple layout but don’t want to get stuck with an incompatible mixer. I have an iPad Air 4th gen (no M1 chip) in case that makes a difference. Thanks.
Hey @Themainman3 ,
Thank you for posting this question here in the Community.
Could you confirm what iOS/iPadOS version is running on your iPad Air 4th gen? Also, what version of djay are you using?
Once you let me know the above I’ll gladly check if we can test this on our end.
Cheers!
Sorry for the late response but both my iPad and djay pro app are up to date with the latest versions. If you could test for compatibility that would be great. Thanks!
