Rane One Beat Parameter
Hi Guys,
I have been going through the various new features in the latest update and have found a bug with the Beat Parameter dial.
Prior to the update the Beat Parameter knob would allow you to change the parameter gradually from minimum to maximum,
Now it just adjusts it to either minimum or maximum and nothing in between,
So basically turning the knob with Echo jumps from 1 straight to 1/16,
In order to adjust it to the other settings l have to do it by touching the iPad, which isn’t really ideal…
Could you please fix this bug…
2 posts were merged into an existing topic: Mixon 4: Mapping of FX beat param + key shift slightly broken
