Please could you add the additional features for the Rane one performance pads that would traditionally be accessed by double taping the patent buttons. I.e double tap ‘saved loop’ auto loop can be accessed etc
Hi @Private_Repress,
Thanks for asking about this in our Community.
It is not currently possible to access the second level of the performance pads by double tapping on the pads menu-button. However, I’ve reported this to our developers and they’ll look into implementing this as soon as they possibly can. We kindly ask for your patience while they work on it.
Thank you for your understanding.
I’ll personally let you know when there’s any more information about it.
Cheers, G
Thanks @Guillermo very much looking forward to this feature
Hey there,
This has been fixed in the latest djay for Mac and iOS updates.
Double-tapping the mode button now changes the performance pad modes:
1st Level ------> 2nd Level
- Hot Cue ------> Cue Loop
- Saved Loop ------> NeuralMix Actions
- Roll ------> Auto Loop
- Sampler ------> Instant FX
- Slicer ------> Slicer Loop
Let us know if you have any questions or problems with this.
Cheers, G
Super @Guillermo another great job!
Is pitch play available? I haven’t found it yet? The other features are working great though!
