Cue Loop is not mapped natively on the Rane One MK2 — it was on the previous Rane One.
But I am not able to find the option for midi mapping manually on Mac OS.
Is there a way to do ?
If not, please add this function as it is my number one tool (instead of using Saved Loop).
Hi @Julien_Apruzzese, please refer to the linked topic below:
There is no special MIDI mapping required to set Cue Loops. Simply start a loop where you want then press an available Hot Cue button to save it as a Cue Loop instead of Hot Cue.
Thank you for the reply but it’s not as useful as having a dedicated Cue Loop mode because you have to save it twice (one for a Hot Cue and one for a Cue Loop).
When the music play, sometimes I want to go to a Cue point without a loop and sometimes with a loop engaged — I use this function every time.
You replied me some times ago that the midi mapping option existed — How can I access the Cue Loop Mode ? - #8 by Slak_Jaw .
But I can’t find the same one when I scroll all midi option on Mac OS.
You’re welcome @Julien_Apruzzese. Cue Loops and Hot Cues have been combined into one. If you want to save a Cue Loop, you first set a loop then press an unused Hot Cue pad. If you want to save a Hot Cue, you simply press an unused Hot Cue pad. There are no longer separate MIDI commands for Cue 1-16 and Cue Loop 1-16.
You could consider using Saved Loops instead of Cue Loops.
Ok — now I understand the change.
It was a great tool for me but you surely had good reason to change.
Last question — is there any other way to go to a Cue point and to engage at the same time a loop (like maybe pressing simultaneously Cue points and loop button) ?
You could try making a custom MIDI mapping using the R-Click Duplicate Mapping for Control feature to map both the Cue 1 and Auto Loop or Auto Loop 8 to the same button. This might result in some inconsistent behaviour though.
Hi @Julien_Apruzzese i also think the command was amazing. I am not sure why it was removed because if you mapped it before, on the device you previously mapped you can still use it. The suggestion of mapping two commands in one will not work.
I am requesting to bring the midi mapping back here:
Thanks for sharing @Ben_Cislaghi
