Rane One not detected on Samsung Tab A7 Lite
  • Device model: Samsung Tab A7 Lite LTE
  • Version of operating system: Android 13
  • Version of djay: 5.1.1
  • Hardware/controllers used: Rane One
Summary of the issue:
DJAY Pro does not detect when the Rane One connected.
How to reproduce the issue:
Connect the Rane One controller to the tablet, launch DJAY to test. No clue.
If you check the list of supported controllers for Android, do you see the Rane One?
Hi @djquartz, please note that the RANE One is not supported on Android. Thanks.
Hello,
Yes I went back and checked. To add some information, I am testing with my TouchOSC template on Android and it’s working with the Rane One…
Being it’s class compliant I didn’t have to do anything and it was recognized and accessible via the TouchOSC app.
Which is a good sign.
