Rane One Pitch Bend While Scratching And/Or Nudging
Apologies if any of these issues have been brought up in the past. I have searched but haven’t found any solutions.
I have the Rane One with an IPad:
(1) When scratching or even nudging the platters, the pitch noticeably bends. This works with and without pitch lock.
(2) My FX section is totally disabled. I am unable to use or even map it to make it useable.
Thanks in advance for the help.
Peck
I have a hunch.
Try plugging in the Rane one to your cam adapter just before you open up the app
Thanks will try this later and report back.
You have the rane one ? No issues with bending pitch ?
It seemed to work somewhat. The pitch bend is still there just not as noticeable. I can’t “nudge” the records without hearing an undesirable change in pitch. The FX section works but as others mentioned, it is split but I’m fine with that.
Thanks gain for your input
Any improvement in this area for you since your last post?
I have the Rane One and use it with my iPhone.
I find using the pitch bend buttons your best bet with key lock off.
Scratching is best with key lock off. Nudging and pitch bending is best done with key lock on.
The mapping is pretty good but it needs a jog mode instead of the platters always spinning. Only in auto mix mode the motor off works with the tracks still playing but with no jog mode manipulation.
Overall I’m happy with this Rane and iPhone combo. My son and I both plug in our iPhones and have fun playing around with it.
Although it’s more that acceptable for my needs it may not be for others.
I’ve had the Rane One for a couple of years now and have no issues with it whatsoever,
I have min heavily mapped to my liking.
I use the Pitch Bend buttons instead of nudging the platter.
No problems with or without Key Lock but I always have Key lock on.
I do wish that the Motor Off button was available although I have found a workaround that as well
