This something I ran into with Serato DJ and fixed it with a colleague using midi code.
What happens is you change pitch ranges and the platter and bpm does not reflect the pitch range change until you move the pitch fader.
Like a turntable when you change pitch ranges the platter speed will reflect that change immediately.
There needs to be feedback to the platter motor to update the rotational speed as per the pitch change.
