Never gigged with the program yet and was going to tonight for the first time. I’m having an issue where when sometimes hitting the search library or sometimes when I switch crates it looses power for a split second and I have to hit play on my controller to keep the music going. It would definitely cause the dance floor to interrupt.
I’m using a Rane One, With 2018 MBP Big Sur 2.2 GHz 8-Corr Intel i7. Latest release of djaypro.
Btw, I analyzed my music. And using my music on internal drive.
Thanks for your response. Yes I’m using the original power cords for my Mac & Rane One. I’m not sure about the usb c cable. It’s Oyaide cable though. No hubs I’m connected straight to my Mac from my controller. I have not tried using a different usb socket. I Will tomorrow.
I have not had a chance to use the program with my Rane One yet. I did use it on New Years Eve on a friends Pioneer SZ and I had no problem. I used a Chroma Cable usb c cord that day so I was going to try and use that cord with my Rane when I have a chance.
Thanks for checking up with me and I will let you know if the new cable helps.
