Hi there I was trying to set the motorized platters on the rane one to deck 3 and 4 but i had no success
Can anyone help ???.
Hi @Djxavo13,
As far as I know, the RANE ONE is a 2 deck controller. Its mixer section is only meant for 2 decks also. I’d suggest you simply use another USB controller to control decks 3 and 4.
We apologize for the inconveniences this might have caused you. Let me know if you have any further questions.
Cheers, G
Thanks for the quick answer i was asking that cause i got 2 rane one devices and wanted keep one of them to control decks 1&2 and map the other one to control 3&4
Is ther any way i can do that ???
Hi @Djxavo13, Yeah I believe you should be able to remap one of your RANE ONEs to control deck 3 and 4. Simply remap every function on each of the decks you wished to edit following these instructions: https://help.algoriddim.com/hc/en-us/articles/360016055199-How-do-I-configure-a-MIDI-controller-using-MIDI-Learn-on-iOS-
I believe you can only have one Crossfader though
Let me know if you have any other questions.
