No matter what tempo range I set the Rane to it seems the range is at +-75%. Not sure if there’s a setting I’m missing in the software or a combination of both. The software says 8%.
So, I unplugged and plugged again and the usb connection and the tempo range issue is gone. However, I’m now having issues with instant doubles. The double starts at the beginning of the song instead of where the other deck is currently positioned. Is there a sequence in which I should power the iPad and Rane one up to avoid these communication issues?
Ended up connecting my laptop to the Rane one using Djay Pro. The stability on the laptop is far superior. Can’t use this laptop for gigs because the screen is cracked. Hopefully the issues will be addressed on the iPad version.
