Anyone have the Rane Performer? If so are you able to cue your next song in your headphones? I cant get anything to play.
Hi @MrG, when creating new topics, please do not forget to answer the questions in our template with specific details about your setup not just “iPad” or “Latest Version”. This helps all of our community moderators to provide the most effective support to users with the utmost efficiency.
Hardware Firmware Version:
Can you please also try to capture a short video of the issue, upload it to your Google Drive/Dropbox, enable sharing permissions, then share a link to the video here? Thanks!
Oops my apologies!
Macbook Pro 14” M3
Djay 5.2.5
Rane Performer
I dont think a video will help any on this since i believe its got to be a setting possibly? Heres my settings. I did change precueing to Rane Performer 1-2 and still nothing
I restarted the mac and performer an switched to internal mode then back to external an now it works. Have no idea what happened.
Excellent! I was about to suggest that you use the Revert or Rest to Defaults button in the Audio Settings. Glad you got it sorted out. Thanks for the follow up @MrG
