RANE Performer motor on sound issue
Playing local files.
In this clip it’s not very clear but it’s happening a few times. Mostly as I press a hot cue pad, and hit play before releasing the pad. Zooming in you see it visually as well. When using more full sound, it’s very noticeable.
You see the beat grid gets aligned very nicely. But then after a second it looses the grid and go back fast again.
This one is using Tidal as the source.
I really hope you can both hear and see.
Sound settings
Thanks @RobustaDK, I’ve shared this with our engineering team.
Hi again @RobustaDK, thanks for the videos. Our engineering team was able to reproduce this and they’re investigating further. I’ll share more when I have it.
Hi @RobustaDK, our engineering team has identified the issue and is working on a fix which should be included in an upcoming update (likely 5.6.3). Thanks!
