Rane Performer not working - 5.3.3
  • Device model *MBP 2019
  • Version of operating system mac OS Sequoia 15.5:
  • Version of djay (5.3.3:
  • Hardware/controllers used (Rane Performer):
Software not responding with waveforms not hot cues…etc…
Hi @djlahawk, welcome to the Community! Can you please capture and share a short video of the issue to clarify the problem? Thanks!
Is connected to correct usb port?
Is the a midi mapping active?
What do you mean the correct USB port?
And as far as midi mapping …why does it have to be enabled the performer doesn’t work “plug and play” with the new update?
Well yes it should be plug and play. Check though to see if it’s there. I don’t have a performer but it looks like it has 2 usb ports.
Ok I understand…let me check
Wow…I feel so foolish …you was right…I had it in the wrong usb port. Thank you for your help
Nice one @Dysfunk_DJ. Thanks for the help!
Easy mistake to make. Don’t be hard on yourself. Now you can enjoy.
