Rane Performer not working with Looper Pack
  • Device model: Mac Studio, M1, 64GB Memory
  • Version of operating system (macOS 15.2):
  • Version of djay (e.g. 5.2.6):
  • Hardware/controllers used (Rane Performer):
Are we working on the Looper Pack in Djay Pro to work with the Rane Performer?
I really love my DJay Pro software and I waited until there was acknowledgment that it worked with the Rane Performer…overall it works, but my Looper within the software wont play. Also would the Pioneer flx10 work better…ie will the Looper Pack play?
Hi @smackdcw,
  1. Please make sure that the Sampler Level of the PERFORMER is turned up. This controls the volume level of djay’s Sampler AND Looper.
  2. Also, if you would like to custom MIDI map one of your Performance Pad modes to control some of the Looper On/Off buttons, I can provide you with some guidance.
I hope that helps!
