Rane Performer vs. Reloop Mixon 8 pro and Djay Pro
Hi again @Sneakdiver, thanks for clarifying. This is not the ideal place to share this information, plus having it all grouped together makes it difficult to properly discuss each item. First of all, please use the search function in this community to see if topics already existing for each item you posted above. If no topic already exists;
  1. Please create a separate Suggestion topic for each request above so other users can upvote them and we can properly document and track them.
  2. Please also create separate Bug Report topics for each issue that you want to be fixed.
I hope that helps. Thanks!
Just fyi: both times they sent reloop 8 it was broken seal. I did not use and returned since I paid for new.
Thanks for sharing @DJ_Faisal
Sure thing! What are 2nd and 3rd best options for dj controller after Mixon 8 pro. I Ike the mixtour pro did 5 weddings on it with external digital mixer, were flawless. Also have reloop ready as back up works perfectly.
I’m also a big fan of the Reloop Mixtour Pro. This is currently my main setup combined with two Denon Prime LC6000’s
Nice. I ran into this video sometime back. May be that’s what I need since Mixon 8 delivery is postponed. https://youtu.be/XO0uLnvOmLU?si=r6U9fSl5Br7psGoU
Yeah, I’ve seen that video as well. There are a few more floating around on YT with that setup. Denon no longer manufactures the LC6000’s so they can be hard to find.
I still see retailers selling lc 6000. Thomann has it on sale. Denon DJ LC6000 Prime – United States
I wouldn’t sleep on it if you find them in stock and on sale.
Hi guys I’m not sure where you are based but here they are in the UK for Ā£269 each. ⁣Denon DJ LC6000 Prime – Thomann UK Denon DJ LC6000 Prime – Thomann UK
Don’t mean to hijack the thread but curious if you tried the RANE 12 MK2’s? Looking to expand my mixtour pro setup with 1 then eventually 2 of the RANE 12’s or Lc6000s on the path to eventually get a true 4 channel mixer as opposed to getting a a new controller so I can still have a portable setup.
Hi @IamNaN, I haven’t used the RANE 12’s myself, but these look like a great fit.
In my opinion having owned the Rane Performer there was a bunch of issues, possible hardware defects while using DJay and Serato respectively separate of course. I went to the local Guitar Center store here in Colonie NY, and they had a AlpahTheta ddj grv6, Denon Dj SC live 4 and a Pioneer ddj flx10 and all of these units worked flawlessly, slight lean towards the AlpahTheta ddj grv6 due to it being usb powered so no need for using electricity and DJ’ing on the spot is a GREAT THING hence the Reloop Ready, now the good thing in my opinion about these units is it connects to all dj software platforms. The Performer has died on many occassions so my next controller’s will be the 3 I had tested out and also the Rane System One, with the hope of the on board stem analyzing and separation on the unit. But as always I say test out equipment to it’s fullest capacity and purchase what works best for you. It’s all about the music.
Thanks for sharing @Thomas.Swift
