Rane Performer with motor on issue
I have an issue with a short sound issue, that only happens when motors are turned on.
After a second after hitting Play, this small interference of the sound happens.
I am on MacBook Pro M3 (24gb), on MacOS 15.0 and djay 5.2.4.
I have a video, but can not upload it here.
Can you upload using drop box, YouTube etc?
Maybe this works
Yes that works but I have to say I can’t hear anything that sounds incorrect. Maybe it’s because it’s a video recording. Maybe someone else can jump into hear and see if they spot something.
You will probably need to hear this on a live system. I guess it’s a thing with the motor.
It’s not there when using Serato.
A longer clip. Recorded in Djay
Hi @RobustaDK,
Thanks for sharing this issue with us. I assume you are speaking about this slight high-pitched wailing/screeching. Is that correct?
Could you confirm whether or not you are only hearing this from the controller itself due to you being so close to it, or is the sound also coming through the speakers of your live system?
This sound is also present when I do recording. So not a mechanical sound if this is what you refer to.
djay 5.5 Release Notes:
  • RANE ONE, ONE MKII, PERFORMER: added motor-off support
