UPD
Hi all! Ive checked current version of native mapping and still this version is far from ideal. Ive mapped some functions, but I can handle only with 2 modes (double tap on ROLL & TRANSPORT which are yellow by default) so I mapped upper row of Roll for beat jump(skip) in serato style (1 and 4 are red and dedicated to skip backward/forward, 2 and 3 for skip size coloured yellow, and bottom row for 1/4,1/2 roll and hot cue1, hot cue 2. and on second layer of transport i mapped transport mode, that is copy of serato transport mode on this mixer coloured same way, but instead of key lock i’ve mapped slip
but first problem: when i switch to one ow this modes all pads are yellow. until i tap the pad and then it changes to colour that I’ve mapped.
2nd problem I’ve tried to map parameter arrows buttons to instrumental/acapella in hot cue mode, but it doesnt works properly, and when ive tried to map other modes ive realized that if i change functions of for example 1st layer of roll and switch to hot cue, the hot cues also activate functions that ive mapped to roll mode. and when i switch off mixer and turned on the only mapping that was saved was on YELLOW modes. If i understood it correctly I can only midi map this 2 yellow midi modes.
I ask ALGORIDDIM TEAM to release real good quality mapping that will be as good as seratol at least.
i really like your product and wish you become a most popular software. please put attention to mapping quality.
RANE Seventy VIIIAIN Edit 3.djayMidiMapping (220.8 KB)
