Rane Seventy Software FX
Hello!
I had a question about toggling between Flex/Hardware FX and Djay Pro AI’s software FX. Is it possible to set up a toggle between hardware and software fx? Or a the very least, being able to trigger software FX from the mixer. I poked around in the midi settings, but couldn’t figure out how to set this up. Any insight would be greatly appreciated. Thanks!
Thank you for getting in touch. At the moment it is not possible to toggle between Software FX (djay FX) and Hardware FX (Rane FX). It is dependant on the mode in which you are using the device (standalone, MIDI mode).
