RANE System One Bluetooth compatibility
YOUR SUGGESTION:
  1. How about adding Bluetooth compatibility between the RS1 and ios devices to control djay pro.
Thanks for the suggestion @Dj_Los_Inthemix. I’ll share this with the dev team for consideration.
I think that would be great, i am noticing that being plugged into an ios device it is not being charged while in use.
If your device has MagSafe, you can use a wireless charger.
theres an application that is useful for making a non bluetooth device communicate between ios and Macos over bluetooth by using midimittr
“midimittr” is a free application
install it on both MacOs & ios, connect your device to either MacOs or ios
within the midimittr application …select source device & select desitnation device
done!
Thanks for sharing @7nz, but I don’t see how you could utilize this between the RANE System One and an iOS device.
Hi again @Dj_Los_Inthemix, I spoke with our engineering team about this. Support for Bluetooth MIDI control with this device is unlikely. The screen requires pretty high data bandwidth and the motorised jogs require low latency - Bluetooth MIDI offers none of those.
