Is it possible to use two Rane 12’s with a controller like the Beatpad 2 or something similar? Want to use the controller as a mixer until I can afford the Seventy. Any suggestions on what would work best?
Hey @DJ_A_Diffrance,
Thanks for asking this in the Algoriddim Community.
Yes! You can connect several controllers and map them however you’d like. Simply connect all USBs to an iOS-compatible USB-Hub.
You’ll find more information on how to map any controller here:
How do I configure a MIDI controller using MIDI Learn on iOS?
How do I MIDI map djay Pro AI’s Neural Mix™ controls?
Can I have more than one MIDI Mapping for my controller?
If you have any questions or suggestions, or if you would like further information, please don’t hesitate to reach out to us again.
Cheers, G
