can i rate & rename songs from finder (and rate at spotify as well) in djay ?
and also i wrote comments on songs in my finder but they dont appear in Djay
renaming is possible outside of djay. Regarding comments, this is not supported as well as ratings.
You can rate your tracks via iTunes, have you tried that out?
Thanks for your answer
The problem is did not all my music is on iTunes
And even the Comments I I put in my finder don’t appear in Djay
thanks
michal
