IPad Pro (12.9 inch) 5th Generation
iOS 18.3
Algriddem version 5.2.8
Reloop Elite
I am unable to use the control vinyl because every time I calibrate, it says that the RCA’s are reversed. I have reversed them and I still get the same message. Any help from the community will be appreciated. I put in a ticket with algoriddems support team over two months ago and never got a response.
Anybody? I see people are viewing the post but not responding. I expected to be ignored by algoriddem,but not the community (smh). I’m done with this DVS.
Hi @Tre_Conley, welcome to the Community! Sorry to hear you’re experiencing this issue.
- Can you please share a screenshot of the error?
- Can you please confirm that you are connected to the Phono inputs on the Reloop Elite?
- Are the input switches on the Reloop Elite set to Phono as well (not Line)?
- Are you using any RCA adapters or extensions?
- Have you tried different RCA cables?
- Are your turntables properly grounded?
- Are you running the latest Reloop Elite firmware?
