Neural Mix Pro - basically - is a means to export stems right? But can you do re-edits - of tracks or stems - within it or do you have to export?
My ideal scenario would be…
Use Neural Mix Pro for stems (obviously), simple track (or stem) re-edits and loop edit/export directly to DJay pro Library, which could then be either triggered in the Sampler or Looper.
This would all be so much more elegant (and useful).
It makes sense that custom loop packs creation will be made as a feature of NMP. Such a UI would need a comprehensive set of features for setting up the length/quantize settings, levels, etc. NMP is MacOS only app and that makes it much easier to do. If the functionality is made in Djay, people would start wanting it on Mac/windows/iPad/mobile … it may take ages to design and then implement it with a reasonable usability and robustness across all platforms.
I would enjoy having the ability to create loop set/looper packs “yesterday”, so the most straightforward approach is most welcome
Also, NMP is paid separately, and I’m OK to pay the extra for having these Pro abilities.
Otherwise, I fully agree that it’d be super cool to have it all within Djay Pro AI, and be able to do it all from within the App.
