Re-mapping controls in djay android
No, it’s not my first language, it’s spanish, jeje
Happy to help :blush:
Thank you very much for that information, for the time to record, edit the video and teach us how to do it… I did the same, I had to install Java on Windows. but I tried to get controllers available in other OS to work… so that they work on Android… I copied the mappings of a Hercules Impulse 300 mk2 and a Numark Mixtrack Platinum FX thinking that when compiling the apk it would work… but no. It does not recognize the mappings. Apparently there is something else that makes it work… because when comparing the Hercules djcontrolmix mappings on Android, macOS and Windows… it is the same… there is a plist file that when opened with notepad… Unfortunately it doesn’t open… I imagine it has to do with something. But Android does recognize the controller’s sound card and audio comes out, but not the midi functions.
Hello @LuisCervants Did you use and the APK from https://apkcombo.com/es/ ?
Why did you need to installa Java?
Hay manera que pueda hacer lo mismo pero para mi vestax typhoon? Y hace unos meses perdi mi laptop. Y estoy a puro cel. Ayuda porfa
Has this still not been addressed? I’m new to the Djay app, using android and unable to find a button to change midi mapping
Hi @angelodeath, thanks for checking in. MIDI mapping is currently not supported on Android.
Por favor, la comunidad de Android exige que coloquen las opciones de MIDI Learn, muchos han pagado la suscripción pensando que estará disponible dicha funcionalidad al hacer la suscripción.
Y si no pueden poner dicha funcionalidad en Android, entonces que sean específicos con esto, para que uno como usuario no se sienta estafado.
Please, the Android community demands that MIDI Learn options be added. Many have paid for the subscription thinking that this feature would be available upon subscribing.
And if they can’t provide this feature on Android, then please be specific about this so that users don’t feel cheated.
Hi @AndersonDJ, welcome to the Community! Thanks for the additional feedback. I will share this with the dev team.
Please midi map on android, I currently using Hercules dj control mix ultra.
Hi @Alex_B1, welcome to the Community! I have merged your new topic with this existing one. Please vote at the top left of this screen. Thanks!
