Read metadata in aiff files
YOUR SUGGESTION:
  1. For some reason my copy cannot read the metadata embedded in aiff liles. Or is this a bug;?
I don’t know what you’re using to write your metadata into your AIFFS, but apparently Apple Music (the app) has a known problem with ID3v2.4 tags. I found that I had much more success using Mp3Tag to write my metadata into my AIFFS.
Previously, I was adding all the metadata in Apple Music and a small percentage of my AIFFS would show up in DJay Pro without the data. Since switching to Mp3Tag to do my tagging, everything has gone smoothly.
Also, Apple Music does not always change the metadata in the file itself. Apple Music has its own library file and it can sometimes only change the data there and not in the file itself. This is why Dougscripts exists.
Thanks for sharing this @Belford_Roxo.
@Sludgeguts does this workflow work for you?
