Reading Serato tags. A way to transfer from Virtual DJ to DJay Pro
Hello everyone. I’m a DJ and a Windows user, and I mainly work with Virtual DJ and Algoriddim DJay Pro. I also have some iPads and iPhones on which I use DJay.
All my song library (local) is in MP3 format, and I have curated and worked on it (tags, hotcues, loops, etc.) for several years with Virtual DJ (an excellent library manager).
After many tests and frustrations, I have created a program that allows me to save Virtual DJ’s hotcues and loops information in Serato format into the tags of the MP3 files. This means that both Serato and Algoriddim DJay Pro can read that information.
It’s the best way I have found to transfer my work from Virtual DJ to DJay Pro.
I have encountered a problem that I’d like to share with you in hopes that you can fix it. It’s not very important, but it is a bit inconvenient.
DJay Pro reads the hotcues and loops information from MP3 files correctly, except when the file name (only the file name, not the internal tags) contains non-English characters, such as accents or the letter ñ. I don’t know why this happens; Serato works perfectly fine without any issues. I’m Spanish, and this forces me to change the names of many files. It would be great if you could fix this.
Another issue, at least on the iPads, is that DJay only reads the Serato hotcues and loops information the first time it encounters an MP3 file. After that, even if you change that information, delete the database, or reinstall the program, it won’t read it again. It isn’t possible to update it. It would be very useful to have the option to force the reading of this information again.
That’s all. Thank you for such a great program, and please, show a little more love to Windows, as we feel a bit abandoned.
Best regards.
Last version of DJay Pro on every device
Windows 10 Pro 64
Good modern laptop
16 Gb RAM
IPad Pro 11" 2021
IPADOS 18.2
1 Tb
IPhone 11
IOS 18.2
128 Gb
Hi @Chirro_Peres, thanks for the careful explanation of your issue and the details about your setup. I’ve passed this onto our engineering team to see if they have any suggestions. I’ll let you know when I hear back. Thanks!
Hi again @Chirro_Peres,
DJay Pro reads the hotcues and loops information from MP3 files correctly, except when the file name (only the file name, not the internal tags) contains non-English characters, such as accents or the letter ñ. I’m Spanish, and this forces me to change the names of many files.
This will be fixed in the upcoming djay 5.3. We do not have an official release date for this yet, but I’ll let you know when it is ready.
This is by design as djay Cue Points take precedence. I hope that helps!
– Ok, thank you
– I understand, but to have the option of rereading this, if you need, would be great
You’re welcome @Chirro_Peres. I’ll let the team know.
Hi @Chirro_Peres, I’m happy to report that this has been addressed in djay 5.3.
For the full 5.3 release notes, please refer to the topic below. Thanks!
Thank you Slak_Jaw :handshake:
“This will be fixed in the upcoming djay 5.3. We do not have an official release date for this yet, but I’ll let you know when it is ready.”
Sorry, but this is not corrected in the last version. I continue having the same problem.
Thanks for the follow up @Chirro_Peres. Sorry to hear you’re still experiencing this issue. I will let the team know.
Hi again @Chirro_Peres, can you please confirm if the file name issue on Windows or iOS?
Hi Slak_Jaw. This happens only on Windows. On IOS is right.
Spanish Windows 11 Pro 64 bit
Thank you @Chirro_Peres
Hi again @Chirro_Peres, engineering has identified the issue on Windows. Sorry about that. It will be fixed in the next djay release. Thanks!
Great. Thank you :slightly_smiling_face:
And please, don’t forget the option for forcing rereading Serato tags.
