Somebody know what is the software’s real system requirements?
In Android if i want to use only mixing with some effects, i can use with my phone with Snapdragon 685 with 8GB RAM, and i can use much slower tab with Unisoc T606 with 6GB RAM. But what SOC need if i want to use the much more power requested Neural Mix? 1 million Antutu points power SOC is will be enough?
In Windows is enough my A8-6410 + 8GB RAM if i want use only mixing with some effects, but what CPU power need if i want to use Neural Mixing?
Thanks for the help! But i need more accurate system requirements. ”Neural Mix supports 64-bit Android and Chromebook devices. Devices using 32-bit processors are not compatible. All supported devices use a standardized Neural Mix quality level, although performance may still vary slightly depending on hardware.” This is a bad joke. You need to make a SOC list or use some benchmark points to make a real system requirements. I tried the Unisoc T606, it worked but sometimes the software thinking too much time, so that SOC isn’t have optimal speed for the basic things.
